caiofilipini
By far the most challenging build I've encountered so far. But you know what, it fired right up!
What a fun pedal. I don't use a lot of modulation tipically, and if I'd have something on my board, this probably wouldn't be it. But I really like having something like that available for recordings and just some inspirational jamming.
I got lazy with this one and ended up purchasing the faceplate, although I did choose the knobs carefully. I also used @PedalPCB's drilling coordinates (thank you!) and had it custom drilled from Tayda. The hole for the LED lens was super tight, but it worked out well in the end.
As some other folks did, I subbed a J201 for the 2SK208-Y, seems to work fine.
Here it is:
Here it is:
