Preverb
You just need a delay pedal with an effects loop and put the low tide in it, then you'll get warbled repeats
Thanks! I had actually just been trying to figure out which pedals can go 100% wet. My solution was slightly more convoluted. Split the signal into stereo prior to the delay + low tide, with the other side dry then feed back to mono after.
I have the Magnetron on my list of builds but not sure if it can be modded to have an effects loop with 100% wet.
