M800 and Twill in the same enclosure
Aaaa... Didn't think about which one I want first. Whatever would be best way of doing it.
I will be using 3 stomps switches.
The M800 is an amp emulator, so usually they go last in the chain. But that's just a guideline. You can get a 3PDT switch and one of these, then you can have it both ways. The Order Switch could be a toggle or another stomp switch. What made you want to use these two boards together in the first place?
To be honest no reason. I was looking at boards and these are the two I wanted to build. I was just thinking I could have two pedals in one enclosure and the output on the PCB TWILL will just go into the M800 input on the PCB.
I personally am not a fan of multiple pedals in one enclosure, mainly because I'm always trying different combinations in search of the elusive TONE. If I wire two pedals together, it takes away the opportunity to find out what it would sound like to put a flanger or delay between them.
