Mach 1 Overdrive More Gain Mods
Tony_Pizza
So this post was in another forum about modding the same pedal. I was told it may be best to start my own forum rather than taking over an existing one. I am new here so pls don't kill me...
Furthermore, someone informed me that another user tried modding the Mach 1 and got some help from Chuck the Wise. I read through that forum and it still did not get me where I want to be with the design.
My ultimate goal here is to increase gain without hindering the "transparent" nature of the pedal. I would also like to implement a switch in order to remove a diode (D2) from the clipping path thus having sym and asym clipping available. As well as a switch to go from low gain (stock) to high gain like the Tommy. Any help and guidance to learn more about this project or electronics and small signal circuit design would be great!
Folks here created PCBs with Chuck's mod
R11 - 1.5K
R12 - 5.6K
C5 - 1uF
C6 - 220nF
I made szukalkis speedysheep with that switchable mod. The C6 really changed the mids and fattened it. So you better should stay with the 100nF.
Best bet would be to breadboard it and check out for yourself.
We get what you're saying, but nonetheless, a clarification of nomenclature.
Splitting hairs aside...
Here's one way to get the clipping you desire:
pcb2-jpg.25473
If you make it an ON-OFF-ON, then the above diagram's switch would offer NO-CLIPPING in the centre position of the toggle.
OR
You can add some LEDs across lugs 2 & 5 to have 3 different clipping options:
clipping-dpdt-2023-04-01-png.45202
Or any combination could go in the middle so long as it has higher forward voltage than the two outliers.
Using all the same type of diodes...
Symmetrical (position 1 or 2)
Symmetrical with Higher Forward voltage (position 1 or 2, whichever isn't already occupied):
Asymmetrical (position 1 or 2):
Symmetrical with extra-high forward voltage to go above the Asymetrical-combo's fV (CENTRE-position):
So you can mix and match — just know that with the lowest forward voltage, ie the CENTRE position, it will always be LOUDER than the outside positions.
[GREAT Avatar, by the way! (y)😸]
i built the Mach 1 and it sounds very nice, but it doesn't seem to have anywhere near the same amount of OD/distortion with the drive maxed as the demo videos show.
Do you have the same amp at the same settings?
Most OD demos are into a tube amp on edge of breakup, and use the pedal to push it past. So you have a combination of a nice sounding amp plus pedal. Take away the nice sounding amp and you just have the pedal.
You can try the gain mod, but it will change the frequency response (more low end) which may erase the "transparent" nature.
For the diode thing, you could just have the switch bypass D2 for the symmetric mode without adding diodes.
A bit about transparent OD
When you clip the signal, the EQ doesn’t sound flat. Clipping the wave adds harmonics which affect how you hear the EQ. Clipping adds some harsh high frequencies. Clipping low frequencies muddies up low mids.
The vast majority of dirt pedals follow this path, to combat the above:
-cut lows before clipping
-cut highs after clipping.
The Timmy is a great example since it gives controls for bass (pre clipping) and treble (post clipping).
If you set the Timmy gain low, then bass and treble knobs at maxed sounds flat eq or “transparent”. As you increase gain, reducing the bass and treble knobs sounds more transparent.
So if you go higher gain on the Lightspeed, it may or may not sound as transparent.
