Synchrony Pedalworks
Early in my pedal building, I made a Mod tube circuit from Amplified Parts. I found that pedal to be lacking, so I was skeptical about this pedal. However, I was wrong. This pedal rips! I preferred the stock (no buffer) and EQ settings. I used 9 Vs, but wonder what 12 would do.
I made one slight error that caused some frustration. I installed the tube daughter board backwards. To salvage the daughter board properly, I had to sacrifice the tube socket and headers. Fortunately, the board did well and was easily rectified with new parts.
This was also my second UV print. It was fairly easy to use Adobe Illustrator to isolate the picture from the original pedal and incorporate it into this project. I was really pleased. Thanks to all of your help and prior posts detailing your process!
