SOLVED Marigold Fuzz voltage problem
TillMack
Hey guys,
Recently build a marigold fuzz with OC140 Transistor.
The pedal functioned, but it sounds kinda gated. So I start measure it.
The biggest problem ist, that I get 4,3vdc at the collector and 0,07vdc on the base at Q3.
The same, when I leave the OC140.
I checked the whole pcb again. Everything is on its right place. Also my solder joint looks good.
Do you have any idea ?
EDIT:
Lesson learned. Russian Germanium diodes have another direction. Now it works fine.
