mybud
You'll forgive me for asking, I trust, but this is either the most subtle compression I've heard or it isn't functioning as intended.
First off, I started by soldering the 5457s in place (biased to around 1.4V as per @andrewsrea's build reports) and used 733s as opamps. When only the level and blend controls seemed to function, I replaced these with sockets (which of course I should've done in the first place
Problems (?): The compression (ratio) knob has little effect on the signal level, if any. It slightly changes the tone but seems to do little else. Likewise, the attack and release knobs do little to affect the signal, it seems. Currently I'm using J113s and 072s but swapping out the JFETs and rebiasing each time doesn't change anything much.
I'm wondering if I've lost my mind or whether the limiting effect is very subtle.
Apart from no obvious compression, the pedal does nice things to the tone (kind of focuses it a bit more clearly) and brings in a lot of top end on the tone control but I'm not convinced it's behaving as it ought to.
Any advice gladly received. TIA.
