MN3006 Based Pedals?
Fingolfen
I know of several pedals that use the MN3007 and even more arcane BBDs in that series... but does anything use an MN3006??? I may have come across some originals...
Maybe there are application notes in the data sheet? I think the 006 part may have to do with the number of stages in the delay or some such.
Sorry @Fingolfen I claim no authority on BBDs but just received a bunch of 3207s which turned out to be duds. Ok, I get that the odd dud is a T&C of NOS components (10-20% don’t work, I believe) but 100% is statistically improbable 🤨 to put it mildly. So, to check that I hadn’t entirely lost my marbles in this regard, I swapped in a known working BL3207 and this worked fine. It’s a bit of a minefield apparently.
That's a weird one. I looked at the data sheet. The MN3006 only has 128 stages, delay range 0.3-6ms.
I found that a Guyatone flanger used one. I don't know of any projects that use one. You might have to make it yourself.
I'd heard about the Guyatone... never seen a good schematic though.
