Modded PNP negative ground - bias pot not working
Jörg
Hi everybody, after only reading here for a while and completing my first FFs (thanks for the great advice in this forum!), here is my first post:
I am stuck. I am building the Jack Orman PNP fuzz face with negative ground. Kicked the fuzz pot, kicked the volume pot, and put a 10k resistor on the output in there for now. I want to have a one knob fuzz.
Instead of the R8.2k bias resistor I put a 10k lin pot in there. The transistors are matched MP40A, hfe around 33. Itworks, and sounds great. Guitar volume does its thing, it goes from just a little boost to a nice low gain fuzz.
Problem is: when turning the bias pot, collector voltage on Q2 only changes from 9.1V to 8.94V. That should be more. I tried putting different resistors in series with the pot, nothing changed.
I checked the wiring, but I can’t find the problem. Anybody have any suggestions?
Thanks!
Jörg
The resistor in the bottom right of course goes to ground. Fixed that and tried different values from 330F to 10k, no change in the bias pot issue. The idea is a on one knob fuzz with bias from close to nothing up to mean evil.
Thanks again if anybody has an idea.
