comradehoser
This may or may not be a troubleshooting thread.
How much crunchiness should I be getting out of this? I am only really getting very tame breakup with boost engaged.
Unity without boost engaged is almost full CW, so it could maybe an issue with Q2 if Q1 is responsible for boost.
Seems pretty quiet and mild overall, so I'm thinking something went awry, as I don't always get on with SMD, and I thought I could rock it with some mmbf4392. Well. Separated a leg off one, so gives you an idea of my proficiency. How fryable are smd transistors?
On the other hand, I am also prone to "is it supposed to sound that way-itis" so I need some independent confirmation, and the only demo I unearthed was a frickin slide player, damn. I am not a slide player.
Ran an audio probe, and there's nothing that jumps out.
Gain pot maxed:
Q1 (bottom) mmbf4393
1: 3.03
2: 3.04
3: 2.48
Q2 (top right). Mmbf 4393
1: 1.95 (variable)
2: 3.10 (variable)
3: 0.5 (variable)
IC 1 ca3130ez
1: .088
2: 4.51
3: 4.23
4: 0
5: 0.88
6: 4.42
7: 9.02
8: 4.75
Ca3130 from Mouser, Mmbf4393 from Ppcb or mouser.
Pins 1 and 3 of Q2 look a bit low compared to Q1, and the fluctuation/instability with gain up make me think that could be it? Q2 is stable with gain down. But what do I know?
I miiiight have one last little smd buddy to try, but I didn't think so. I have bad luck with these guys in particular.
[Edit: tried reflowing Q2 following with what has worked for me in the past: liberal flux on the legs and a retouch with a solder loaded tip. Now I have no output at all ]
Gain pot maxed:
1: 3.03
2: 3.04
3: 2.48
1: 1.95 (variable)
2: 3.10 (variable)
3: 0.5 (variable)
IC 1 ca3130ez
1: .088
2: 4.51
3: 4.23
4: 0
5: 0.88
6: 4.42
7: 9.02
8: 4.75
