Monoprice Stage Right 15W amp rebuild
Well, meaning their PT's may not last long... The post was a guy reporting the same symptoms, a member that repairs amps had two different mono's come in around the same time with shorted PT's...
Every product has issues. There isn't a product sold thats 100% fine. You get bad parts out of the box in every industry. Musical instruments. Amps. Automotive parts. Computer parts. Electronics. Whatever.
They ALL have products where you can and do find dead products right out of the box. It's part of manufacturing. No manufacturer can make 100% faultless products, where every single one works flawlessly. There's ALWAYS ones that don't work. It doesn't mean "they may not last long". There's absolutely zero logic there in connecting those 2 things. None. Zip. Zilch. Nada.
I've had my Monoprice 15w amp for 3.5 years and it's never had a single issue. So then with your logic, that means they probably do last long since we're using sample sizes of 1 and 2 to make determinations of quality for the entire line. Lol.
@vigilante398 what'd you do with the internals of the Monoprice amp? I just got a new Hot Rod Deluxe, so I was looking into removing the chassis from my Monoprice 15w to do some maintenance. That's how I ended up here, from a Google search on how to remove the MP15 chassis. Does it just slide out once you get the screws out? Should I lay the cab down on its back and slide it out that way? Or just stand it up and slide it out the back?
Didn't even realize I had an account here already lol. Going to clean the pots with Deoxit and I've got some Telam EL84s from a matched quad that I want to install. So I'll rebias the amp at that time, too. I've got a discharge tool and 1000v rated alligator clip leads and the standard leads so everything ought to be fine. The volume and drive pots are both pretty scratchy around 0-2 so I'm hoping this will cure it.
Telam EL84's though this isn't where I bought mine. I got a matched quad for half the price of 1 tube from them.
As an expert in manufacturing, all I can say is Scrap/MRB/Rework is the most important part of product development, along with version control, operator tracking, etc.
Sounds like they may not have a firm grasp on that yet. Good luck with the iron.
I'll be honest, I'm not really sure what I did with the guts. They're either somewhere floating around my mess of a workshop or they're in the garbage. I don't think there was any real reason for me to keep them so I probably trashed them. Removing the chassis is pretty straightforward once the screws are out, but it's a pretty tight fit with the tolex in there, you may have to wiggle it a bit to get it out.
Well I guess I can circle back on this thread. I got tired of the empty cabinet sitting there taunting me, so I designed a new chassis for it from scratch, and I used a pair of brand new transformers from Musical Power Supplies instead of trying to make it work with the originals. So the amp has been gutted and a new amp was built in its place, but since I changed literally everything I don't think it's fair to call it a "rebuild" anymore.
I did end up doing a Lightning because it's something I've built a few times before and I know I like. Guts aren't super duper clean because I'm a sloppy human being, but it works, sounds great, and is pretty low noise. I have faceplates coming soon, at which point I will also be re-tolexing the cabinet. When I do that I'm planning to cut the wood out around the chassis, I didn't account for that when I designed the chassis so things are a little too close to the edges.
Almost ready to close this one out. Finally motivated myself enough to re-tolex the cabinet last night. I'm doing new grill cloth as well, but I ran out of staples so I didn't get that finished, that will have to happen tonight. Hopefully I can keep motivation long enough to get this thing out of my damn workshop.
@vigilante398 That looks great! What’s your EF86 of choice? Is is true that those Monoprice amps are really re-badged Laney Cubs? I’ve a friend that has one of the Laneys and he gets some good tones out of it. I’ve considered getting one of the new Super Tops since everythings gotten so expensive and I’m in need of an EL84 amp!
I was redoing my layout for the lightning when I realized there were preamp caps grounded with the power caps. I came up with this layout that should minimize ground loop hum. Nevermind the name at the top, I was just screwing around with something I could call it besides a trademark, lol. There's a line out and a resistor to make a proper load if no speaker is plugged in.
Lightning just uses 12AX7 in the preamp, but I have a nice British Mullard EF86 in my DC30 that sounds magical. And yup, these are really re-badged Laney Cubs, with the 15W being the Cub 12 and the 5W being the Cub 8.
@vigilante398 Actually I remember chatting with you over email about EF86s and that you had one or the IEC branded Mullard silver plates. Those are some of my favorites and I remember reading somewhere that the Mullard silver plate was Mark Sampson tube of choice for the DC30 after an extensive shootout. I think it was for the DC30. I’ll see if I can find that article.
I was trying to decide which thread I wanted to keep spamming with this, then I remembered I have my own section here, so I can leave everyone else alone and post my garbage here.
I'll start with background: Six months or so ago I picked up a 15W "Stage Right" amp from Monoprice when they were on sale, and it came to about $203 shipped. You can't buy transformers and tubes for that, let alone a Celestion speaker, a reverb tank, a chassis, and a pretty well built cabinet. Hard to turn down when they come on sale. But I don't need a two-channel amp, especially a Marshall-voiced one. So this morning I decided to gut it and build something new inside.
I had thrown together a layout this afternoon, then when I got home I opened up the amp to take some measurements and adjusted the layout accordingly. One benefit to this being designed for easy assembly, it's incredibly easy to disassemble, I had it stripped down to a bare chassis with transformers in under 10 minutes.
So basically this will be the EF86 channel of the Matchless DC30 feeding into the 15W power section of the Matchless Lightning. You lose the reverb because I don't want to deal with it, but I left in an FX loop. Also the Monoprice has a lower voltage tap on the power transformer to feed the opamps for the reverb and FX loop (yes they're both opamp driven there's a handful of TL072 in there), and I decided to regulate it down to 12V and use it to drive LEDs. I had an idea I want to try out, and figured half a dozen LEDs would be useful. I will still have to drill a couple holes in the chassis to mount the PCB, but fortunately the chassis is aluminum and not steel, so it won't be too bad. I can reuse the existing holes for everything else I need. Once I've verified that this is a worthwhile project I'm planning to get a replacement faceplate so it looks nice and stuff.
Here's the chassis for now, still need to remove the power switch and jewel. I'm trying to decide whether I want to keep the attached power cord or if I'm motivated enough to cut a rectangular hole for an IEC power cable.
The useless garbage.
I’d like to do something like this with a MonoPrice 15w amp that is acting up. Where did you get the new PCB?
It's a turretboard, not a PCB. I made it myself.
Looks good! What about the sushi box PCB in your earlier post? I can’t find anything like that. I’m tempted to transform my monoprice 15w into something different and better, and it would be nice to have a pre-printed board to follow. Any suggestions?
Take a look at evolve DIY. They might have something for ya. Also, consider taking a stab at a turret board.
I mean I am Sushi Box, so that's obviously where I got the PCB earlier in the post, but both versions had some issues so they're definitely not good enough for me to sell. I wanted to use a PCB because I have a lot more PCB design experience than turretboard design experience so I assumed it would be faster/easier, but when it turned out not to be I just used a known-good turret design from Ceriatone.
