B baol New member Jan 17, 2023 #1 Hi everyone. Does anyone have a chart with the correct Moonshot values? Thank you
Feral Feline Well-known member Jan 18, 2023 #2 baol said: Hi everyone. Does anyone have a chart with the correct Moonshot values? Thank you Click to expand... https://docs.pedalpcb.com/project/MoonshotTremolo.pdf Upvote 0 Downvote
B baol New member Jan 19, 2023 #3 Feral Feline said: https://docs.pedalpcb.com/project/MoonshotTremolo.pdf Click to expand... Thank you, I got it, it's the only thing available on the net about this effect but there's nothing I'm looking for Upvote 0 Downvote
Feral Feline Well-known member Jan 19, 2023 #4 You can compare the PPCB schematic/component values with all the other DIY trems based on Culturejam's Shoot the Moon Tremolo. Plenty of versions: Rullywow's is called "Lunar Blast"; It's on Tagboard, Dirtbox layouts, Effects Layouts, DIYstompbox, GuitarPCB... It's in turn based on the Tremulus Loon tremolo, which Small Bear has a version called Tremululous Bear or similar. So I'm not sure what you mean by "correct values" or "there's nothing I'm looking for" What are you looking for exactly? Upvote 0 Downvote
B baol New member Jan 19, 2023 #5 Feral Feline said: Plenty of versions: Rullywow's is called "Lunar Blast"; It's on Tagboard, Dirtbox layouts, Effects Layouts, DIYstompbox, GuitarPCB... It's in turn based on the Tremulus Loon tremolo, which Small Bear has a version called Tremululous Bear or similar. Click to expand... ok, thanks I'll look for them Feral Feline said: So I'm not sure what you mean by "correct values" or "there's nothing I'm looking for" Click to expand... I was looking for the voltage values in the various points of the circuit to understand where there is something not working properly Upvote 0 Downvote
Feral Feline Well-known member Jan 19, 2023 #6 baol said: ok, thanks I'll look for them I was looking for the voltage values in the various points of the circuit to understand where there is something not working properly Click to expand... Madbean is usually very good for voltages. Either in the build doc itself or on the mb forum. Upvote 0 Downvote
