Hi!
This is my second pedal build. I got the kit from musikding.de I built the kit but now I'm having some troubles. The pedal powers on and led is lit. I get the signal through the key in & out but the led is not responding to playing. I know it should change color when I play indicating when the gate closes and opens. If I connect all four cables, I get the signal through. If I tweak the pot it acts like a volume control (all the way up the signal dissappears). If I engage the range switch the signal dissappears (and led turns to red). I did the testing with all the parts connected and inside the enclosure.
This kit had those 9 pin switching jacks. I wired them so that 4 & 3 were connected and used as a tip connection (blue) and 2 was used as a switched tip (black). The blue wire goes on the board to the connection with letter T next to it.
Here's some photos (I removed the led, but it was connected when testing).
