Muzzle
Redredbettyz
Anyone give this PCB a shot? I get no signal and the THAT 4301 gets very hot in a short amount of time. I've gone over the board for cold joints, or misplaced components a few times and everything looks good. Does it sound like I got a bad THAT IC? I hope not, that thing was not cheap.
That's correct. You'll need to temporarily install a jumper wire across the Key pads as well.
This could explain why you aren't getting any output, but the THAT shouldn't be getting hot regardless.
EDIT: Verified that the THAT doesn't get hot in normal operation
An LT1054 getting hot usually means you might have a short somewhere. Double check for any solder bridges. If you buy charge pumps from authorized places, you should(99.99999% of the time) never get faulty ones.
Can confirm on the bad LT1054, bad luck I guess. They have been my preferred charge pump because of lack of issues i've run into with them. I put a MAX1044 in there temporarily to check if I could get signal through, and it worked with some background noise issues (as expected). Got a new batch of of LT1054's in today and it fired up perfect. Thanks for your input!
Awesome! This one is next in line for build docs.... Just in the event that you want to wire up the Key input.
Yes, I'm very interested in the key input feature. Does it involve using a TRS jack and wiring it to short when there is no 1/4" plug present? If so, I can probably figure it out before you get the build documents out.
