Elijah-Baley
Hello,
I built a few years ago the Muzzle for a friend. I was really impressed by it! After I built it I test it with my friend: I used its TU-2 to split the signal, used the Input key and put the pedal in the loop effect. The 4 cable method. I tried the distortion channel of the amp but even with a DIY Triple Wreck in front of the amp.
This noise gate was incredible: zero hum and no loss of sustain or attack, and it didn't cut the feedback. And bypassing the Triple Wreck the clean was totally intact. Indeed we thought that this noise gate can be always on with no problem.
(Now I'm using some different gear: tube amp, a DIY Revv G4 and a DIY buffered splitter.)
This second Muzzle (the only difference is the new triplet smd chip) is not fully convincing. If I rise up the threshold enough to decrease a bit of hum I start to lose sustain and attack. I lose volume to decay of the note, it blocks the feedback. And it ruins my clean sound when I bypass the distortion.
I have to choice between still much hum or too gated sound.
What's happen to this circuit?
