Need help finding capacitors C2, C3, and C6 for Terrarium
dynothunder
Hi all, I'm looking for some help trying to figure out what capacitors I need to buy for the Terrarium, namely C2, C3, and C6.
These are listed on the spec sheet as 1 uf MLCC capacitors, 7.2 x 2.5mm. I'm also aware that when it comes to audio gear, one should be using capacitors with a temp rating of C0G, not X7R, as they have less background noise. Looking online for these capacitors however, it seems that they're basically not a thing? Or if they are, they're very rare, very expensive, and definitely don't come in the specified size.
This is my first time doing this, so it would be greatly appreciated if someone could point me to which capacitors I need to buy here! Thank you!
These are what I use, regardless of any forum warnings: ;)
If you're really concerned about the capacitance dropping with DC bias (the primary "issue" with MLCC) then just bump them up to 10uF, but it's really not necessary.
Thanks for the feedback!
I'm getting my stuff on digikey, would this be a suitable equivalent then? https://www.digikey.com/en/products/detail/kemet/C333C105K5R5TA7301/6562349
