Need Help Identifying Connector Type...
Caldo71
Hey gang—I posted this over in "troubleshooting" forum and (uncharacteristically for this board) received ZERO replies. But it may be because that was just the wrong forum choice on my end, since in hindsight this is not a PedalPCB build specifically? So let me try this question again on this forum...
ANYHOW, this connector (see photos below) connects the two stacked PCB boards on my FreeTheTone PA-10G graphic EQ pedal.
I need to move the two boards farther apart, as I’m shifting its guts into a 2RU rack housing. So I need a little ribbon adaptor with male/female connectors to do the trick.
As the photos hopefully show, it’s got two rows of eight pins, and is around 12mm in length.
Can someone tell me what this type of connector is called? I tried exhaustively doing search terms for it on Google to no avail...
