New amp recommendations.
Dan0h
I have been jonesing for a new amp for months. Getting burning pockets waiting for the Supro Amulet to come back in stock.
Drop some good suggestions below. Im all over the map on what I want. But August is my BDay month and I’m going buy something damn it. lol.
Reactions: fig
Synergy stuff looks really cool. I have an MTS rig which is it's predecessor. Oddly enough, the synergy preamps go for less than the MTS stuff on reverb.
There was a cool kit I was going to recommend, a Supro-Sears kind of Hybrid (a Silvertone 1430?), but it's disappeared.
Mod Kits MOD102+
The MOD102+ expands on the same all analog vacuum tube classic American circuit design combined with a British style Class A output section as the Original MOD102 with additional “+” features. These special features include a three position progressive toggle switch for off-standby-power and additional push-pull functionality for each control - pull out the bass control knob for “mid boost”, pull out the treble control knob for “bright”, pull out the volume control knob for “turbo”. These new features and a JJ ECC803-S (a long plate 12AX7 known for its complex mid range tones) allow for a wider variety of tones and extra control for the user.
MOD 102+ Guitar Amp Kit Features:
All-Tube Design (solid-state diodes used only for full-wave rectification)
8W output power into 8 Ω
1 channel
Vintage channel controls with push-pull functionality: bass (+mid-boost), treble (+bright) and volume (+turbo)
Vintage pilot lamp and screw-on jewel cover for power-on indication
Output Impedance: 8 Ω
Tubes included: one ECC803 (JJ Electronic brand preamp tube), one EL84 (JJ Electronic brand power tube)
Hammond Mfg 269EX power transformer and P-T31 single ended output transformer.
Cathode biased class A power tube operation (no bias adjustment needed).
Point to point hand wiring using terminal strips
Carbon film resistors
Metalized polyester coupling caps
Pre-punched steel chassis
Assembled Kit Weight: 5.55 lbs.
Assembled Kit Dimensions: 10" Width x 6" Depth x 5 1/8" Height
EDIT: Not sure why the Mable link is in Chinese, it was the URL from Mable's English-Language site: www.mableaudio.com/en/
