devanbumstead
Just completed a Clandestine Preamp build. It's a unique enclosure meant to sit underneath a POG2 so the jacks and switches are on the sides. Truly...it's "Clandestine"
The pedal works as expected when engaged--signal is processed like it should be, it sounds like my Chase Tone Secret Preamp, the LED lights up, the toggle switch controls the Bright/Dark/Mid modes appropriately, the volume knob behaves as it should...but when bypassed, no signal comes through.
Surely it's the switch or something surrounding that, yeah? I ordered this 3PDT Low Profile Footswitch - Latching from Stomp Box Parts. Turns out I had plenty of space inside and outside for a regular one if that proves to be the issue.
The inside wiring isn't as pretty as I wanted it to be but it seems to be fine otherwise.
Also, you'll see two extra power jacks in there...that's just to run aux power to the side of my board when needed, it's not a part of the Clandestine circuit at all.
Thanks for your eyes and knowledge!
