Dirk Speicher
Hi everyone.
I've build a chaos machine. Kit was complete by a webshop in Germany, so all correct parts were in the pack. I do a lot of diy soldering and repair.
When the pedal is inactive, Bypass works . Activatin the pedal, LED is on, but no Sound.
I have checked: all the capacitors, all ICs and the orientation, all the wires and shortcuts. Tryed without the enclosure, . What i can't check, if the ICs and transitors are all working. Do i miss anything ?... Looks like an amlifier does not work , so that there is no Output ??
In the pic you see, that i switched the Colours from the power Input. I've changed that during the search.
Thanx and greetings from germany
Dirk
Dirk
