Hi all,
I've build a Nobelium which I got through Musikding in Germany.
Build went well, although I have some issues.
First issue: DI out sound very thin and lower in volume compared to line out. I know Line out has an extra gain stage, but the DI almost sounds out of phase.
Bass and Treble do work, but also a night and day difference with the jack out, which all has the tubey goodness and thickness.
I've reflowed the Unagi xfomer solder pins. Pin 1 is orientated correctly.
I did measured a plate voltage drop to around 60V at pin 1 of V1.
Second issue: the potmeter shaft thread is to short. Including faceplate, the thread barely sticks out. I already filed away a lip on the potmeter chassis. That worked for 2 of the 3 potmeters, but one still wont grab on to the nut.
Anyone got a suggestions to solve these issues?
Thanks!
Joel
Thanks!
Joel
