Nut Driver build
Vild
Build Rating
3.00 star(s)
Shitty tube screamer variant. Build the plumes or dunes clone or something. (Or just buy a plumes)
Soundwise I have pretty much the same experience as the guys in this thread. I almost wondered if I did something wrong. It's weak.
Post in thread 'Hortin FexDrive layout 3' https://forum.pedalpcb.com/threads/hortin-fexdrive-layout-3.28453/post-368739
Something I learned with this build though is the metallic chrome tayda paint jobs are thick enough that the ppcb template won't fit correctly over it but I made it work.
that's unfortunate.
box looks great though! maybe could save it for something else. (would probably fit an UberDrive quite nicely)
when this one first showed up in 'upcoming releases' i was pretty excited to see it and possibly breadboard the circuit.
but, sadly, its just an 808 with a poor choice of clipping diodes.
fortin could chuck any old circuit in a box, write up some marketing spiel about how they've carefully tuned it to snap necks (with 1 or 2 component value substitutions) and every metal simp will want it because fortin.
if you want a good overdrive that actually make your amp react and chonk the way you want it to:
or the OG
Thanks for the tips! If it's that close to a normal 808 it should be easy for me to try to find some good mods for it or something. I haven't really looked at the circuit much but I probably should have. I definitely trusted Fortin too much on this lol.
no worries 🤙
if you want to try some different clipping diodes, you could pull the x2 mosfets and drop in a clipping switch here:
(sw1 & sw2 to the points circled in red, can just use a regular on/on DPDT)
Oh hell yeah thanks!
Not sure if there is a good spot for the switch, I'll probably just run some jumpers to a bread board and try some random ones out and see how it goes.
