Ocelot question
Markus
I just wrapped up an ocelot, and it seems Ok except the volume of the 2 octaves are very low. The normal volume works fine, just the octaves are very low comparatively. I’ve never played an original to compare this to, so I’m wondering if there’s an issue somewhere, or if the lower volume is just a character of the circuit. Thanks!
The OC-2 is like that too.
On Bass, the famous setting is -1 Oct maxed with the other two registers muted. The same thing with -2 Oct just doesn't work. Guitarists typically find the -2 Oct to be unnecessary too.
Once I reflowed it worked perfectly both octaves equally loud matter of when I dime the octaves it gets a little glitchy sounding like it’s too much octave
