DGWVI
- Build Rating
- 5.00 star(s)
This is a Mask Audio Electronics board. I'd originally built it to their Big Clang spec, and it was meh. So, I tried the Albini spec. It's was even more meh. Today, I decided to just use the specs from the Percolation Station build doc, except I used different transistors and diodes, and I'm quite happy with how it turned out. Sounds awesome buffered or unbuffed, and it gets quite a bit louder than using straight germanium diodes.
Transistors are Toshiba 2SB54 and BC109C, diodes are a GAZ51 and an infrared LED
Decided to use one of the NOS 1590B-sized Bud EconoBoxes. I left all the oxidation and grime, as I feel it matches well with the sounds this boxes gets
Have some clang
Fairly easy build, even though I basically had to rebuild it thrice
. MAE makes some great boards, though
Have some clang
