One-of-Four Generic Logic Switching
Cybercow
We've been wanting a 1-of-4 switching solution for our RMS X100 V3 pedal so the user could select any one of the four basic preamp Modes on this pedal. For this version of the RMS X100 V3 we wanted one stompswitch per mode option with no bypass switch.
Earlier this year, our esteemed team leader found this schematic from an old DIY forum post to work from . . . .
After trying this out on a breadboard, it was found wanting in a couple of points.
1) It has no switch-debounce and the logic did not always hold when a switch was selected.
2) Boot-up is inconsistent and does not always boot-up in the same logic state.
After futzing with it on the breadboard . . . .
I was able to achieve solid switching action by adding a 100nF cap to each of the momentary-on switches pull-down resistors.
And a consistent boot-up default state was achieved by adding a clamping diode to one of the switches.
As for power supply, I found that this circuit works best at least +9V. Below 8 volts the logic outputs and LEDs begin to exhibit threshold operation. So, 9V seems to be ideal.
Here is the final schematic in generic format for anyone who wishes to pursue a similar solution. It can also be used for a 1-of-3 switching solution by omitting switch #4 - but leaving in tact the switch #4 pull-down & debounce cap.
Hope someone finds this useful.
Hi Cybercow,
Hello from Japan.
I saw your posts about the One-of-Four radio-button style switching circuit, and I’m planning to build a 4-loop guitar effects switcher based on this idea.
I would like to use four momentary footswitches, with only one switch active at a time — pressing one switch should automatically turn the other three off, like a radio-button system.
If possible, could you please share the Gerber files for the final improved version of your One-of-Four PCB, including the improvements for switch bouncing and stable power-up operation?
I would also really appreciate the latest schematic, BOM, and any build information you may have.
Thank you very much!
The schematic above is the latest and works. But here it is again . . .
And the BOM . . . .
The Gerbers are HERE. (< clicking this link will just download the Gerbers zip file.)
I've no other recorded build notes for this project.
Hi Cybercow, I previously asked you about this circuit.
I have now built the latest Alternate Schematic version and it is almost complete.
The circuit works perfectly during normal operation. Once I press any of SW1–SW4, only one channel is selected at a time, and all four channels switch correctly. The LEDs, relays, and audio paths all work correctly.
The only problem is that the default boot-up state is inconsistent.
At power-up, I sometimes get:
CH1 only,
two or more channels selected simultaneously, or
no channel selected at all.
Interestingly, if I switch the power off and back on within about 5 seconds, the previously selected channel is restored very consistently. However, after the power has been off for a longer period, the initial state becomes unpredictable.
I have checked the Boot-Up Clamp wiring, including the polarity and connections of C5 (10µF), the orientation and connections of D5 (1N914), and the R6 (100kΩ) connection. D5 measures approximately 0.552V forward and OL in reverse using the diode-test mode.
With the circuit powered off for a sufficient period, I also measured resistance from the D inputs to ground. D1 measures approximately 49–49.5kΩ, while D2–D4 measure approximately 100kΩ. This seems consistent with the schematic, since the two 100kΩ paths on the D1/Boot-Up Clamp section appear in parallel.
I have also tried different 9V power supplies and the behaviour is unchanged.
I am still considering the possibility of a wiring or soldering mistake on my build. I made the PCB very small, so the construction is quite dense.
From these symptoms, is there any particular part of the circuit you would recommend checking, or any specific voltage/resistance measurements around the Boot-Up Clamp that would help diagnose the problem?
D5 is the correct place to start for troubleshooting this circuit when the boot-up state is inconsistent. And you've not overlooked the debounce network consisting of D1, R1 & C1 thru D4, R4 & C4. (If any one of those debounce triads is off, it can upset the consistency of operation.) I can't think of where else to look. We've not experienced any inconsistency issue with the boot-up state or other switching issues. You might need to go so far as to trace the entire circuit to find the problem.
I removed C5 (10uF) and tested it out of circuit. It measures about 8.81uF.
The normal 1-of-4 switching operation works correctly, but the boot-up selection has been inconsistent. I have checked the wiring, resistors, diodes and connections around the boot-up clamp.
I’m going to try a new 10uF capacitor next. Could 8.8uF instead of 10uF make the boot-up clamp unreliable in this circuit, or should 8.8uF still be more than sufficient?
Would you recommend trying a slightly larger value such as 22uF if a new 10uF does not solve it?
8.8µF is within the 20% tolerance of electrolytics, so that should be fine. And it won't hurt anything to try a larger value. I dunno what to say about the inconsistency issues you're experiencing. I took one of the built-out prototype boards I have and tested it over and over with zero issues yesterday. Have you observed the logic levels with a scope during boot up?
Thinking more about it, let's see some pics of your build, if you please. Not sure if pics will expose anything, but just to say eyeballs were laid on them.
