LandFillSessions
When engaged there is a squeal or whine clearly related to the randomize oscillator. It’s not boxed. I bought a real shallow water to compare it to... yeah i did. And it does the same thing. Is a diode malfunctioning? J201’s were mounted on adapter boards instead on the smd pads. I need to reseat the pots with the dust covers as I’m sure it’s shorting out. Help on isolating the whine would be appreciate.
A daisy chain power supply will cause noise in the other pedals so an isolated psu is needed.
