debrad
Finally getting around to building my Panspermia (PCB112) and I think I just ran across an issue between the build documents and my board:
On the bottom row of the board, I have two 10k resistors on the left while the documents show a single 10k resistor beside two 100n caps. This seems to give me five 10k resistors on my PCB while the build documents only have four...
Here's mine:
Here's the build document:
In addition, one side of R2 (10k) on my PCB board has a direct connection to pin6 of the OpAmp and no connection to Q1 while the schematic in the build document shows R2 connected to the collector of Q1 and no connection to the OpAmp (having said that, I think they both connect to VCC...).
Bottom line, is it possible that there is a different set of build documents that match my PCB...and can anyone explain why my board layout appears to include 1 more 10k resistor than the schematic?
Here's mine:
![Board.jpg Board.jpg](https://forum.pedalpcb.com/data/attachments/75/75746-9f6686c1f9c2a793bad4dfbb0c9ce2b2.jpg)
![BuildDocPCB.jpg BuildDocPCB.jpg](https://forum.pedalpcb.com/data/attachments/75/75747-8d2ff85915c013ea7b197988d94e79a9.jpg)
