Yep, it's mentioned on the product page for the Paragon.
The components are all exactly the same. You can connect the two PCBs with wire or pin headers.
This allows the main board to sit lower in the enclosure if you use PCB mounted pots with regular length pins. This is entirely optional of course, if you already have long pin pots you can still use those.
