Combo Pedals - Do I just chain the output to the input of the second one?
airbud
Hi all, I have a couple combo build ideas, but my first is pretty straightforward: op amp and transistors big muffs, with two footswitches and a toggle to flip the order.
My intuition tells me I can just wire up the inputs and outputs to the order switch utility PCB and call it a day, but before I go nuts doing anything I wanted to make sure I knew how to do this "properly."
It seems like doing this might "waste" components in that there may be some duplication of buffer and power supply-related circuitry. Or does all input/output impedance matching still apply as if they were separate pedals?
Thanks!
Oh, and I'm calling it the "Double Stuff."
You could just use a switch without any pcb
You mentioned „waste“ so skip the pcb.
They are still seperate pedals just with another switch in between.
I wouldn’t worry about waste of components as long as you there are no redundant pots or expensive transistors.
exactly the information I needed!!! the pic is extremely helpful, I'll be saving that as well as the switching diagram.
I had already bought a couple of PCBs but moving forward I'll go with this method.
Thanks guys, I really appreciate it!
