SOLVED Paragon mini, no bypass, only right side LED
Status
Not open for further replies.
Raspymcnasty
Hello,
I just finished building the paragon mini in a gorva and it was a super tight fit.
I plugged it up and i got no sound. No bypass, and only the right side’s led works.
I have a feeling it’s the switch wiring to the board.. instead of wires i used those breakoff pins that you use for the regular paragon, however, since it wasn’t lined up i broke each piece off individually and soldered each one on.
Can anyone confirm that this is probably the issue or could it be something else?
Link to photos
Status
