I am building a Paragon Mini and I am starting to solder in the components. The paragon mini is a dual pedal with two sides that can work independently. You can convert the pedal to a high gain option by swapping a 1K resistor for a 100K resistor at a specific point in the circuit.
I'd like to make one side with the high gain option and one side without and I'd like to make the first side of the pedal the high gain one. However I am not sure which of the two resistors at issue (R3 and R20) I should put a 100K resistor in.
Does the right switch (marked as 2 on the pcb and which seems to control the bottom half of the components) come first in the circuit and go into the left side (marked as 1 on the pcb and which seems to control the top half of the components)? This would follow common right-to-left pedal chain order. Or is it the opposite and the left side goes into the right side (which would follow the numerical order of the pcb labels)?
I would appreciate any advice anyone can offer.
