BrainTentacle
Hey all, Finally my first post here after lurking for quite some time and of course it is a troubleshooting problem that has me stumped.
I have built a Parenthesis Fuzz and would like to incorporate the Intelligent Relay Bypass on the octave section so it can have momentary switching capabilities. I have looked through several builds and threads and did find one where it was incorporated but was only able to half-gleam the wiring from the pictures.
Current state: Distortion and Boost work as expected and sound good. With no relay bypass board installed, if I jumper OCT_1 to OCT_2 I have normal operation with no octave. If I jumper OCT_2 to OCT_3 I have the octave permanently engaged. This all seems to work as expected to me so I think there are no issues with the main PCB.
(Side note here that this logic doesn't really track for me as far as the schematic labelling of OCT_1, OCT_2, and OCT_3. But, it does seem to be as it should looking at the wiring for a regular 3PDT in the wiring photos of the build guide.)
In my attempt to add the relay bypass module I wired it as follows:
OCT_1 -> JACK_OUT
OCT_2 -> JACK_IN
OCT_3 -> IN
OCT_4 -> SW
OCT_5 -> GND
With this I am not able to turn the octave on. The pedal functions normally otherwise, as it did when I jumpered OCT_1 to OCT_2. It does not seem the relay is switching to me, I am getting continuity from JACK_IN to JACK_OUT and also from IN to ground. The LED is not lighting either. I have used my momentary switch on another pedal and it worked fine so I have eliminated that.
I am hoping one of you fine folks can double check that my wiring scheme seems sound and if so, let me know if there's any way to diagnose these Intelligent Relay Bypass modules. I have the components to build another to test but haven't made it that far yet.
Thanks all in advance!
OCT_1 -> JACK_OUT
OCT_2 -> JACK_IN
OCT_3 -> IN
OCT_4 -> SW
OCT_5 -> GND
