Mike McLane
Just built a new Pauper, but it won't give me a peep!!! I get the guitar thru the bypass, but the only thing I get when powered on is a pop when switching from BOOST to OD. I have double checked all component values as best I could, re-melted all of the solder joints and double checked that the foot switch is functioning properly. Still no change. The Op Amp and the MA856 diodes came from a previous build that went "south" when I inadvertently damaged the PCB. Was wondering if the IC is possibly shot from the wear & tear of the previous build. I included a gut shots just in case. Any suggestions?
I double checked all of the component values I could, remelted all of the solder joints, the TONE pot is not grounding out, the switch appears to be working properly.
