I am getting odd voltage reading on this build. On the 5817 diode, I am getting 9.44V going in. When I check the voltage coming out, it slowly increments up to around 135 mV coming out. R12 matches this voltage and R13 is roughly half of R12, and pin 5 on the IC is roughly equal to R13.
If I pull the 5817 and use a jumper, the voltages are much more what you would expect.
At this point, I'm simply perplexed.
