OD is Glorious
- Build Rating
- 5.00 star(s)
I like it. It is a great little overdrive/distortion with the ability to get dirt, subtle boost or transparent overdrive. I messed with it a while and decided it is good. It is relatively transparent and amp like, but when you start turning the drive the circuit transitions into a thick saturated distortion. If you work that presence knob you can make it dark, or give it shimmer. At full clockwise on the dials it gets textured fuzz.
I used a Tayda 1590b in pastel green. From there I distressed the case slightly, then added the waterslide decal and several coats of Spraymax 2k clear. The MXR style side jacks are enclosed, and the D.C. jack is Lumberg. I used the PPCB LED breakout board for the footswitch. I moved the footswitch higher so that it could be positioned for the decal. The LED is a 3mm red diffused in a freznel. I used some reflector top black knobs. For that B22k potentiometer I just tested all of my B20k until I found one that is 22.8k.
I have built one of these before and will likely build another because it is good. Definitely build one if you like any of the overdrive or distortion variants.
Notes
Notes
- B22k potentiometer does not exist (I think) so use your multimeter with your B20k pots to get close
- You need an A50k and a C50k potentiometer
- You need the LM741 op-amp
- You need an 8v2 Zener diode for this build
- This all fits easily in a 1590b, but you will need the short electrolytic capacitors. PPCB has them.
