szukalski
- Build Rating
- 4.00 star(s)
So, I built myself a Chickenhead but didn’t box it up because I wanted to do a UV print enclosure. It sounded great and I really like how it stacks.
Around the same time, I built an Aphrodite because I liked the demos. It’s supposed to be based on a Klon but I don’t hear it. I had an issue with some fake TL072s but worked it out in the end. I also enjoyed this pedal, especially in stacks (it goes well with either blue or green side of the Pro-10 Dual).
I tried it with the Chickenhead and really liked it so wanted to build a 2-in-1 and I had a 1590BB spare to part with. I wanted independent sides, so went with dual input/output like the KoT option. If you only connect the first and last sockets then it goes Chickenhead into Aphrodite, but you can run a patch cable to go the other way, or just run one side.
Sound wise, you get the nice TL072 crunch, driven by the Germanium booster. For a really flexible setup, I run Chickenhead > Pro-10 > Aphrodite and have six really usable but unique tones.
Knobs were just what I had on hand, they’ll get replaced in the next Tayda order, but they work for now..
Build rating is 4. The boards were straight forward, but the wiring and enclosure was fiddly.
