PedalPCB FV-1 Dev Board Passes Dry Signal But No Wet Signal
ffs_auggie
Just got done building my PedalPCB FV-1 Dev Board! Loaded up the rom_chorus_rev and it programmed fine without failure with AsProgrammer (I made sure I had the correct driver to detect the CH341). The mix and volume work fine but I dont hear any of the actual wet signal. I looked back at the datasheet and made sure that all the voltage readings were correct, which they are. Any help would be much appreciated!
