OD is Glorious
- Build Rating
- 5.00 star(s)
Edit 2/22/26: After putting this pedal through its paces I see that it is basically a dirt pedal. No transparent OD and you get severe dirt when you toggle north and dirt south. I would call this a distortion pedal with a switch that toggles into fuzz territory,
I loved the build. Using ¼ watt resistors makes populating the board much more pleasing. I spent more time to get the board looking clean and made sure to enjoy the journey. Usually I am rushing to a destination but I have been learning by following posts here and learn by studying the clean work of the members. If you build one of these, you’re gonna need a few obscure parts like a D100K potentiometer and 1S1588 diodes. .
I have gotten used to having a toggle switch on a pedal after getting into Wampler pedals. It is nice to have a switch, maybe two… but more than that? Too much. So this one has just one switch and I made it a short shaft Taiway. The S1588 diodes seem to give this a very fuzz-like, very compressed/sustained distortion when you toggle north. and toggling south you get a more open and airy overdrive.
Right now the pedal works great, it just feels very underpowered to me– without being an expert I suspect I may have a bad 5534D which I purchased from Amazon (when I started making pedals I ordered many parts there) – Today I only tried one Amazon 5534 that you see here. I ordered some NE5534P ICs from Stompbox today: Google told me they were the ones to replace the NSJ. For the rest of the pedal, I was sure to take my time and test all components. The pedal worked on the auditorium platform immediately. I am probably going to wait on the final boxing until I get a proper NJM5534D unless someone sees another reason why the pedal may be underpowered. @MichaelW completed one and said in his build report that it operated like a gain pedal. Fingers crossed that all I need is a proper 5534 and please let me know if youn see anything wrong here. I do love the tone and voicing of this circuit; even though it sounds a bit brutish and transistory.
Components
Components
- Green powder coated 125b enclosure from Tayda
- PedalPCB board and top jack face plate
- 1S1588s were sourced from an Ebay seller and they are great. Recommended by @MichaelW
- Mural on the pedal top was done with Adobe Photoshop. The design was printed on a clear thermal ink label on a brother QL-1110NWB Edit 09/28/2026 I no longer use this type of label. I use traditional waterslide. The QL-1110NWB uses heat to make black, and it is not meant to be a permanent label.
- Resistors are ¼ watt
- Mini on/on Taiway switch from Love My Switches
