OD is Glorious
- Build Rating
- 5.00 star(s)
I keep returning to this circuit because the ROI is usually great. Today... everything went wrong. I have previously stuffed this in a 1590a but this time... I had nothing - there are barely any parts but I had no signal. Bad BC108, wrong volume potentiometer installed, LED issues from footswitch. Long story short at 10am I started populating this board (takes about a half hour) and boxing this circuit. Nine hours later I had a working pedal. It was extremely frustrating and also rewarding because I figured it out. I then messed with the trimmers until I was tired of it and gave it a good enough designation.
White powder coated 1590a enclosure with decal and 2k satin clear coat. The knobs are 12.5mm aluminum - two gold one red. In person the enclosure is stunning. I used a red 3mm LED soldered directly to the board and a clear freznel. Lumberg DC jack and enclosed side jacks. Low profile footswitch with breakout board. 9mm off board potentiometers. I did bend the two electrolytic caps down although I do not think it was necessary. I used 22 gage prebond for all wiring.
Notes:
- Test your BC 108s.
- You really just need one short 47u electrolytic cap and PPCB sells them
- Do research about how to bias using the trimmers - I just used my ear
- The LED soldered directly on the board works great
- Making sure the sundial knob is centered with the decal requires planning no matter what size enclosure you use
