PedalPCB Splendiferous Drive (Mad Professor Royal Blue Overdrive)
bluedmc777
Build Rating
5.00 star(s)
This is only the second of several of Bjorns circuits I intend to build. The first being the Fuscia Fuzz which is absolutely killer. This one also does not disappoint. It doesn’t sound like a tubescreamer or Timmy thankfully it has its own sound. It can do light Od to almost distortion. However it does use LEDs as clippers which I’m usually not too fond of unless it’s a distortion but this pedal pulls it off well. I do wonder what a set of Bat41s would sound like though! Easy build and recommended. Thinking about trying the Symbolic drive next.
The Bee Sting is more transparent while the Royal Blue is more “rough around the edges” so to speak. To me the LEDs can get harsh if the eq isn’t tuned it properly. The Silver Bee can be useful set almost anywhere. I believe the Royal Blue has more gain on tap though. Hope that helps. I’d give it a go. It’s doesn’t sound anything like a tubescreamer or Timmy. I should probably put them both aside and a/b them but that’s what immediately came to mind.
@MattG was it you that told me you used magnifying glass some during your builds? That’s how I figured out my eyesight was getting bad because I tried some of those Dan Erlwaine type magnifying glasses. 😂
I’m gonna do the symbolic and skylight very soon so I’ll post my thoughts on those as well. Have to finish the Mojito Deluxe first.
Not for through-hole builds. I have a lighted, magnifying headset that I sometimes used when hand-soldering SMD parts. I've also used it for debugging a few times. Although, for debugging, I've found that my phone's camera zoom is actually the best "magnifying glass" I have.
@MattG I went back and a/b the two pedal and they’re both very close in sound. The obvious sound differences is in the clipping diodes. If you put Bat41s, which is what I think the Bee Sting uses, in the the Royal Bkue they may be indistinguishable.
I recommend trying it but socketing the diodes. That sounds like a nice experiment
I’m not sure who told me that then. It may have been @HamishR Either way it’s really helped me.
FWIW the Bee Sting is not strictly a Bjørn design. In the original Honey Bee, Silver Bee, Honey Beest those diodes are usually LEDs. Some folks LOVE 'em - I don't! So I swapped them for BAT41s. The Bee Sting was an experiment of mine because I wondered what it would sound like if I replaced the CA3130 single opamp chip and JFET arrangement the Silver Bee inherited from the Rat to a dual opamp. The Silver Bee sounds great as it is but I wanted to hear what a dual opamp version sounded like and it is significantly different while still having the lovely complexity of the original. And that is the Bee Sting. Still two gain stages but achieved with slightly fewer parts. And a slightly different sound.
And I use a hand-held magnifying glass to check solders. I have very good glasses these days but I still like to see with a magnifying glass because eyes can deceive.
Just want to update my review of this pedal. The more I play it the more I like it which is uncommon for me with overdrives! Usually I get tired of them pretty quickly. Also, I like the sound of it more through my Deluxe Reverb. I think it has something that do with the brightness of the pedal and where the highs sit.
