OD is Glorious
- Build Rating
- 5.00 star(s)
So I completed this pedal a few weeks ago but it did not work on the PedalPCB platform so I set it aside. When I came back to it I saw that I had inserted the wrong op amp in the TLC2262 spot so I swapped it out and it worked straight away.
So this pedal required setting the internal trimmer. Initially only one position of the toggle switch worked, so I set the internal pot and it all worked. Boxing this was very tricky without the use of my left thumb, but all I had to do was connect jacks. I have one more pedal already populated that I may be able to complete soon.
I used a great Tayda enclosure and 1/2 inch vinyl letters. The knobs are 15mm purple which contrast with the fluorescent green case. I used a Taiway Dpdt short bat on/on/on switch. Again I went with the Love My Switches breakout board which requires my using that jump wire for the LED and swapping the ground and switch out wires. It seems like a good useful Tremolo; previously I built the woodpecker and this is somewhat comparable. What I like about this circuit is that the tremolo from this pedal can get more smooth and wavy than the abrupt woodpecker.
