jubal81
The return current for both sides would always be that Layer 2 GND plane. The only reason you'd need the extra GND vias to steer them is if you have two GND planes.I think the thing about sig/gnd/sig/sig is that the bottom copper signal is quite far away from solid copper, so you're back to thinking about return currents on those traces and placing a bunch of vias where it jumps a trace on in.2
Granted, one signal layer is 0.2mm from the GND plane and the other is 1.5mm. If you're laying out a 2-layer PCB, the ideal would be a solid-uninterrupted GND plane on the bottom and all your traces on the top and 1.5mm away.
What I'm suggesting is a "3-layer" PCB is a foolproof approach that will give better results than a 2-layer design.
