Building Plaid Preamp. As I don't have a drill, I ordered an enclosure with drilling from Tayda using the template provided on the PCB page.
I can't figure out what type of 2.1mm power jack should fit an 8.1mm hole. The ones that I have are too big...
The same goes for the hole for the LED. It is 4.4mm - too big for a 3mm LED. I guess the LED should go with a bezel. I would appreciate it if someone could point to a bezel that would fit the hole.
Thank you, and Happy New Year!
