PPCB Phase II [1590B]
jcpst
5.00 star(s)
I’m excited about wrapping this one up. I love the Duo-Phase, but it’s large. While I really like two phasers, I can do my thang with one phaser.
This board has a compact layout. Which is cool, because I was able to fit it in a 1590B, my preferred enclosure size. I used the 2.5mm wide 470nf caps, a low profile foot switch, and a Cusack enclosure.
So far, this is my favorite phaser. This one was for my board before I started working on it.
For the trimmers, I just turned them until I got the sound I liked the most.
The labels are hard to see, but that’s ok for me- I know what they are.
Well crap, now I need to re-house mine in a 1590b!!!
I mentioned the Cusack enclosure (the “pro” enclosure at stomp box parts), but to add to that, I wasn’t able to fit this in a regular 1590B as-is. The one I use has an extra 1mm of clearance due to thinner walls, and it makes the difference when trying to box this one up.
While I could put the board inside a regular 1590B, I wasn’t able to get it to sit deep enough. I bet a few 0.1mm of sanding on the pcb or filing on the inner enclosure walls would do the trick.
Wow! Great build Anyone else drooling over the ground wiring? That looks really sleek and clean!
Thanks! That was a happy accident. I absentmindedly stripped all the insulation off my ground wire instead of just the end, so I rolled with it.
