Falterthethomist
Hey guys, I have a Pro 10 Blue build with very low, and somewhat gated output, but I can't seem to find the issue.
I traced the signal path with an audio probe and everything seems fine until the feedback loop of the TL71. After R13 there is a significant signal loss which continues to pins 2 and 6 of the opamp and accordingly to the output pot. The signal going to pin3 of the Tl71 seems fine.
I triple checked the values of all the resistors and the caps there, but they should be ok. I also swapped the Tl71 with no difference.
Do you guys have any ideas? Or did you run into a similar problem?
Thanks.
I will send pics of the board asap.
Thanks.
