Hey everyone,
I'm running into an issue with my Sanguine build. This is my 14th build, and it's the first time I've had a problem like this. The circuit works, but when the pedal is engaged, the output is attenuated. So the signal is still getting through but the clean signal noticeably louder.
The only obvious issue I've encountered so far is that two potentiometers (mid and treble) broke while buliding, so I desoldered them and replaced them. While removing the mid pot, I suspect the solder pad for leg 1 may have come off, but when I checked for continuity, everything seemed OK.
I can tell that the volume and gain pots, as well as the aggression switch, are functioning properly. I'm not entirely sure about the mid pot, and I’m having a hard time determining whether the treble and bass controls are working as they should.
To troubleshoot, I also swapped out all three op-amp ICs, but that didn't change anything.
Has anyone encountered a similar issue or have any ideas on what to check next?
Thanks!
Thanks!
