Problem with JHS @+
Sasan
Could anybody tell me what could be the reason for this issue with the JHS @+?
In the video (zipped since I couldn't attach otherwise) you see the working one first and then the one with the issue...the LEDs are low and the sound is weak; both channels behave the same, probably some powering issue?!
The pics show the working one on the left side.
  • video-1620015107.zip
As you have noted, the one with low output has dimly lit led which points to a power issue.
Do you have a DMM ( Digital Multi Meter) ?
Can you check or swap pedals around & see if it is getting 9V through the Power supply to each pedal?
Any updates on this?
