DGWVI
- Build Rating
- 5.00 star(s)
Just finished this up today-
Pythagoras (Ring Mod, LoFi Machine, Pitch Shifter) into Squidward (Life pedal specs) into Pythagoras (Ring Mod, LoFi Machine, Pitch Shifter)
Each of the Pythagoras' have the clock module installed, and I used a 20k for the clock frequency pots to give em a bit more range on the lower setting. Only mod to the Pythagoras boards are 100k for R11-, so I can punish whatever comes after them if I want. These are also wired with the Intelligent Relay boards
Squidward is built to Life Pedal specs, but I used BC series transistors. This is wired using the regular 3pdt daughterboard.
There's an FX loop between the Squidward and second Pythagoras
I didn't install exp jacks because I don't really ever use Expression pedals, but I made sure to leave enough room between the jacks in case I change my mind
Anyway, no demo just yet. I plan on a deep dive, and a couple of comparison vids(Ring Mod vs Frequency Analyzer & LoFi Machine vs Sonic Reducer) once my roommate wakes up
