Quick question(led)
masonlewisdiesel
Still really green when it comes to effects
Quick question(s):
1: Is that indeed true, that all I need to do is jump the main pads "A" to "K" to utilize the daughter board's LED pads?
2: I have not put a LED in yet, but should I be seeing 9v at all times? effect on and in bypass? doesn't 9 seem high given the clr?
Everything works. I will wait for response before moving forward with removing tranny socket and led install.
Thank you for any input that will help.
Range-finder PCB
Daughter board PCB594
R IMG_4987.jpeg IMG_4988.jpeg 6 470ohms
With nothing installed in those pads you have an open circuit so reading 9V on the empty LED pads is normal.
Yes, install a jumper across the A/K pads of the Range Finder PCB since you're using PCB594.
