Rangefinder volume cleanup?
Johnny
I picked up a prebuilt Rangefinder and it is a great pedal. However, rolling back the volume to clean up the signal is not what it is with other pedals. I notice a big volume drop at about 9 on the guitar whereas without the RF, the signal is just less drive which what I expect.
Is this common for the RF? Seems like other Rangemaster TBs are supposed clean up very well with riding the volume.
The voltage is 9.3. It is a Mullard OCP 71 transistor.
I did not change anything and it appears that all the correct parts were used in the build.
I did not build the pedal so not sure where parts are from.
I am measuring the source voltage at the power Jack “hot” lead.
update…tried a different meter and now I am getting 9.3 volts at the source and -6.95 on the Collector.
the collector voltage seems good. Is there a buffer or another pedal between your guitar and the RF?
Hmm, not sure what to suggest then. I had a rangemaster on my breadboard a few weeks ago but took it down--don't recall it having that issue, but also don't recall if I tested the volume roll off... likely I would've though.
Here’s pix of the board. Not able to do the underside right now. I do know that solder bridges and loose connections can occur on the best of builds, but this appears to be done very well.
3 of the resistors were placed with the values to the board making them unreadable.
The transistor is light sensitive, as expected. While I had it open to adjust bias, it would make noise in the light and go away when covered.
The IC is a 7660S.
All semiconductors are light sensitive, some more than others. Even LEDs can be used as photodiodes.
Back in the Paleozoic, when I was fresh out of school on my first job, one of the QA guys called me over to where he was testing radio receivers in the parking lot. The receiver enclosures were open so he could measure voltages. Bob said "look at this, why do you think it's doing this?" He'd stand in one place and the radio was working fine. Then he'd move a foot to his left and the radio would stop working. I was at a loss. No clue why it did that. Then he said "now look at this" and he held one finger so that it cast a shadow on a 1N4148. The radio started working again. Bob was an old Ham radio operator. He told me "silicon diodes are photosensitive. When sunlight hits 'em, the go into full conduction." At the same place we had some Motorola microcontrollers. They contained UV eraseable PROM and had a clear window on top for erasing them. The PROM and microcontroller were on the same chip. We had to cover the window when they were powered, otherwise normal room light was enough to make the microcontroller malfunction.
